Old 06-09-2008, 11:05 PM   #15 (permalink)
whokilledthejams
Boxhead
whokilledthejams's Avatar
Boxy Brown - '04 Scion xB
90 day: 35.48 mpg (US)
Send a message via AIM to whokilledthejams
Hello,
The switch I want would let me turn off the A/C when the windshield defrost is on. On my Scion xA, you can't have the fan blowing air on the windshield (only) w/o the A/C being turned on...grrrrrrrr.
Ever drive in an ice storm?! (You don't need no stinkin' A/C, that's for sure!)
I've suspected that the xB has this "feature" too. I use the defroster setting as sparingly as possible, as a result, even though I've never heard of it specifically. This is common to a lot of cars. Some let you disable it by simply turning off the AC, whereas others don't let you know that it's even on.
In the Subaru I had previously, I disabled the AC-with-defrost by taking apart the HVAC controls and physically breaking the tiny switch for the AC. It worked well like that. If it wasn't 200 degrees outside, I'd explore this in the xB.
