All new, in the middle of the C (top and bottom of the picture) will get 2 more body mounts to replace the cracked and rusted ones there. The sections under the door frames will also double as rock sliders.
There isn't enough room to do it with the box tube, but I am connecting the top of the hoops, then between the middle and back hoop at the top of the tub I will connect them. That should strengthen and stiffen up the body by quite a bit.
