Originally Posted by sendler
It will be interesting to see what the gearing looks like in gearing commander. That engine would probably be capable of cruising 100 kph with PnG at 2,600.
It's at like 3000-few rpm at 100km/h if I remember well.
...I googled up the reduction ratios of the two bikes (the NC700S and F650CS) and the difference in (primary*final) ratios is ~1.23, which gives ~3254rpm for the NC700S, via the factory sprockets (taking the F650CS as 4000rpm at the same speed).
(I had an easy job they having the same 0.84:1 highest gear and the same 160/60 rear tire.)
