get a pertronics electronic distributor kit and get rid of the points if it is equiped with it now. buy a rebuild kit for the carb, and aviation form-a-gasket for the edges of the gaskets. but before that rule out a vacuum leak with a squirt gun , worm and idle the engine,squirt the vac. line connections if you have a leak the engine should smooth for a moment. good luck
