Pick your shift point, probably close to 2500-3000 RPM depending on the engine. When you use higher gears and load the engine up properly for economy you can have 80% load at lower throttle positions. Beyond that throttle position adding throttle will have little effect on you rate of acceleration.
regards
Mech
