1 has rich or oil , 2 looks normal, 3,4 normal or no spark,or lean condition at idle. sounds crazy but what do they smell like,oil,fuel. as I recall it runs ok at speed ,how is your charging system & battery may not be enough power output till its up in rpm's or fuel pressure is low at idle . Lots for you to check .
