Thread: Carb rough idle
Old 10-03-2012, 04:36 PM   #7 (permalink)
ron
double eagles - '99 Dodge ram slt
90 day: 19.48 mpg (US)
if you have a leak on the suction side of the pump it should be worse at speed with higher fuel need, not to mention that the fuel should show up as a puddle or strong fuel smell when not running. I think the real issue is you need someone to properly trouble shoot this thing with hands on,Like the mechanic who said rebuild the carb . do it yourself if your are able and save $ . it sounds like a place to start
