Old 10-03-2012, 08:40 PM   #25 (permalink)
Dave Philips
Tire diameters
I don't see that you've corrected for tire overall rolling diameter between the wheel and tire sizes you are comparing. You may have significant odometer and speedometer error/ changes as a result of the wheel and tire swaps that you should correct for. I agree that a smaller/lighter wheel and tire will often lower rolling resistance. Also, narrower tires probably will have less drag. Tire Rack publishes accurate tire diameters for each tire they sell.
