Originally Posted by CigaR007
I would clean my car's catalytic converter but given the complexity in removing it, I much rather not touch it since it seems to be working as it should. That alone tells me the catalytic converter is running at near 100 % efficiency, even after 11 years.
I do appreciate the effort you put into this though. Any action that can prolong the life of a vehicle and its parts is commendable.
A real test on the efficiency of yer converter is to do an emissions test. Hours of operation or mileage would be a better indicator than time.
Here's how to remove the converter on yer 2001 Echo...
How do you replace the catalytic converter on a 2001 Toyota Echo
