What Sometimes helps is to replace the front rubber brake hoses. They can deteriorate and restrict oil flow in both directions. U won't feel a difference in braking ability but the brakes won't release as well. Also, your calipers might need to be replaced. If the brake doesn't slide back and forth on the guide pins real easily then u have a problem. Clean and grease the guide pins and see if that helps. If not, buy new calipers.
