I ran my high mileage (200k plus pontiac vibe) in lean burn all the time with my supercharger and it lasted about 25k miles..probably woulda of lasted alot longer if i hadnt went to a smaller pulley and kept my foot outta the pedal. Oh and i also was using water injection for anything over 6-7 psi...Long story short if your running low boost no more then .5 bar, then you should be able to run lean for short periods with out any negative effects.
The car manufactures are owned by the government and the government is owned by the oil companies. Any questions?
