Thread: Vacuum gauge
Old 12-29-2007, 12:12 AM   #12 (permalink)
Coyote X
nut
Coyote X's Avatar
Metro XFi - '93 Geo Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 Suzuki DR650SE
90 day: 55.26 mpg (US)
Send a message via MSN to Coyote X
A digital voltmeter would be cheap and easy to install but will only work to show you vacuum at a 0.5 second sample rate or whatever the voltmeter does. So with that you will not be able to see any jitter or needle vibrations from an engine problem.
You can find a cheap diagnostic type vacuum gauge at advance auto/autozone for under 20 bucks that works great. It isn't backlit but that would be easy to wire in if you need it. The great thing is you can see a lot more about how smooth your engine is operating with that needle than you can measuring any sensors. You can tell when it is time for a tune up or any small vacuum leaks that would be impossible to detect otherwise.
Either way will be good enough to help control your throttle and improve mileage but with a vacuum gauge you can get a lot more information and keep your car running in top condition.
