Originally Posted by Piwoslaw
So the closer you live to urbanized areas, the more gas you use? I wonder why, since urban areas are usually more compact, so you have only 2-3 miles to the store, not 20-30 like in rural areas.
I think you interpreted the maps incorrectly.
The first map is simply the consumption in each county. The second map shows consumption per capita, and it tends to show rural areas as higher consuming (per capita). The 2 maps essentially contrast each other. High county consumption areas tend to have lower per capita consumption, while low county consumption areas have higher per capita consumption.
It's reasonable to assume people in rural areas drive further and are more likely to own a pickup truck.
