Old 10-05-2012, 06:29 PM   #36 (permalink)
aerohead
results
Originally Posted by ACEV View Post
Attached air flow is exactly what one needs to remove.
One can't argue with results, unless they want to replicate the tests.
Using clay is an excellent method because it can be removed. And let us not forget the extra weight the clay added.
The proof is in the pudding. No theoritical laws mean anything if the process works anyway. Observation is the only true sientific method.
By the way, this is not about windows. They cannot be helped and that is why they are removed in fast cars.
MetroMPG has interesting points, but the test should be done with fuel injection and a air-flow sensor to meet the exactness we need to see.
One can also do the test both ways, different times of day, etc.. But I am not convinced that such a large difference is needing any more detailed tweaks. It pretty much stands alone.
Their 'results' violate 'science.' If Jaime is the 'engineer' he should have remembered from Fluid Mechanics about boundary layers and Reynolds number effects as pertaining to the scale of automobiles.
Dimples on golf balls are boundary layer devices used to force a transition to turbulent boundary layer and alter the ball's separation point.
Automobiles are already in full turbulent boundary layer above 20 mph.Dimples would be redundant.
The dimples could act as turbulators,energizing the boundary layer to achieve attached flow in areas of high angle of attack (rear of the Taurus),but a drag reduction cannot be associated with pure Rn.
