Old 10-06-2012, 01:07 PM   #112 (permalink)
RiderofBikes
Pantry Boy Supreme (pbs) - '04 Volvo S80 T6 Premier
Originally Posted by radioranger View Post
why not make a opening in the lower grille and cover with a screen so at slow speeds more air will flow through and faster you go more air will bypass but still get some cooling
The way i have it setup, is so i dont have to fiddle with it later on, it takes not even 2sec to adjust the openings before i leave or on my various stops to account for temp changes and or A/c needs, this is also why i want it to be controlled from the cabin like i plan to do (whenever) i get around to a wedge front end
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
