you are probably right on that , but i would think an accumulator like they use on drag race cars would ensure no damage could occur, course it adds expense, although every cold start would benefit and another benefit i forgot is you can run less oil in the crankcase which is a big deal for MPG or at least power production as crank will not be hitting as much oil in the pan,
