Old 10-07-2012, 09:01 PM   #21 (permalink)
DoctorM
Originally Posted by SmellyCat View Post
I install rear wheel skirts and ground skirts and a rear spoiler. Is there a chance I've created more drag? What if I seldom drive over 50 mph. Could the front skirt and grill block possibly create more drag at low speeds? Sc
Speaking to wheel skirts -- Look underneath your car at the bottom -- there is a very high probability there is nothing aerodynamic about the underside of the vehicle, and all the air moving through and around your underside components is likely to be very turbulent. Unless your wheel wells are isolated from that turbulence (highly unlikely) wheel wells are not likely to be effective at low and moderate vehicle speeds. And if you have designer wheels with sharp edges, they're not likely to aerodynamic either. Even if you put moonhubs on the outside of the wheels, the other side of the wheel will still be turbulent.
Wheel-well skirts may be effective at high freeway speeds, but I think any gain would be small and difficult to accurately measure.
Aerodynamic fairings around fixed gear aircraft wheels do reduce parasitic drag, but typical aircraft fixed gear aircraft using wheel fairings normally cruise at 100 mph and well upwards of that. Aircraft operating below 100 mph generally don't bother with them - often for reasons other than speed, such as operating out of soft-fields.
In the final analysis, you should test them on and off your vehicle. Realize that you can very easily subconsciously affect the outcome of the test runs with a lighter foot with then on than with them off, which would invalidate the test.
Notwithstanding the psychological aspect, I for one would be very interested in your test results.
