Thread: Engine Braking
Old 10-07-2012, 11:32 PM   #32 (permalink)
kennybobby
Southern Squidbillie
For a motorcycle yes, but not for cages...
Your understanding of an alternator is correct for a permanent magnet alternator such as is used on motorsickles--they run all the time and dump excess current back into heat. But we are only talking ~30 amps. The magnet drag is probably 1-2 hp in order to make .5 hp.
In most cars the alternator uses a claw-pole rotor that can be controlled as needed to meet the electrical load demand. The higher your electrical load, then a higher current into the rotor and a stronger magnetic field is created, and more mechanical power is required to turn the pulley. And visa versa for lesser electrical loads--the rotor can be turned off and freewheel.
The Following 2 Users Say Thank You to kennybobby For This Useful Post:
Mustang Dave (10-08-2012), redpoint5 (10-08-2012)
