Old 10-08-2012, 08:40 PM   #61 (permalink)
Galane
Originally Posted by hamsterpower View Post
A little late to the thread here. I know you said you had an alignment, but was it aligned for handling or efficiency? There is a big difference. I also really think you need some narrower, harder tires for the rear. Drag radials are way to sticky.
Most efficient is zero rolling toe-in, but it can make the steering twitchy. Getting to that can involve adjusting the static toe-in several times.
