Old 10-10-2012, 08:56 AM   #4 (permalink)
seeodywhy
It could be coming from the Vtec switch. I had that problem before. As far as the distributor seal is concerned you have to make sure you either get it from Honda or that you make sure you have the correct dimensions. You need to clean out the orifice with a dry rag and then cover both the hole and the new o-ring clean oil before installing it. I would never buy a new distributor just to replace the o-ring.
