Old 10-10-2012, 10:06 AM   #1 (permalink)
Miller88
XJ Cherokee - '00 Jeep Cherokee Sport
90 day: 12.96 mpg (US)
FoFO - '11 Ford Focus SE
90 day: 36.78 mpg (US)
Reinstalled Grille Blocks ... Few Questions
First cold morning yesterday. For some reason my Focus just doesn't make heat quick - the dealer claims everything is working correctly.
My 8 mile drive to work was cold until I got to the last half mile; then the car started making some heat.
I blocked off the lower grilles from the outside with b lack duct tape, then blocked off the INSIDE of the upper grille with the same duct tape.
Good news is - I had the same amount of heat within 3 miles this morning! I was at full heat and engine was at full temp by the time I got to work (according to digital temp gauge).
So I have a few questions.
If I blocked the upper grille from the inside ... does that have any affect on aerodynamics?
If the engine warms up quicker, I'm assuming that will cause a bit lower internal resistance (oil, trans fluid) and help mileage a bit.
Also, since the engine draws in it's air from the engine bay, did i effectively make a WAI? I'm assuming this will also help with mileage.
I can't wait for the first real cold snap to see how good the heat is!
