Originally Posted by darcane
Not sure if the head is different but I would guess not. You still have the CPU, exhaust, and O2 sensor from the Texas car, right?
When you get your Ultragauge. watch the rear O2 sensor. When it drops to 0.000 you should be in lean burn. I can feel a slight stumble or a slight surge when it enters LB or leaves it.
Everything but the head is from Texas. So I guess I should! I'm pretty excited to get the ultragauge to be honest. I'm a nut when it comes to tracking numbers and such.
