Old 10-10-2012, 04:53 PM   #6 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
On my way into work this morning (~40 deg F outside), my truck took 16 miles to get up to full operating temp--and that's with the cab heater off, coolant and oil heaters plugged in all night, insulating blankets on the engine & grille completely blocked off.
What you have to remember is that the more efficient the engine is, the less heat that gets put into the coolant. I was thinking about that this morning...the amount of heat that goes into the coolant is a function of 1) the amount of fuel burned, and 2) the fraction of that fuel energy that goes into the coolant. So let's compare my truck engine to say a Geo Metro. If we both got 40 mpg, then we both burned the same quantity of fuel. Even if the engine efficiency was the same that would mean I put the same number of Btu's in my coolant and the Geo Metro did to his--except I have a whole lot more coolant and cast iron to absorb all that heat. So no wonder it takes so long to warm up. If I were getting 10 mpg I'm sure it would warm up faster because I'd be putting 4 times the amount of energy into the system.
I'm going to try to get at least a front belly pan on here shortly and hopefully that should help somewhat too.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
