Old 10-10-2012, 08:42 PM   #9 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Originally Posted by Miller88 View Post
The odd thing is, this is a small aluminum engine with an electric fan that turns on *only* when needed. My Jeep, with a big cast-iron engine and mechanical fan that is ALWAYS spinning full bore ... warms up almost instantly. Never understood that one. Hmmm.
The running the fan won't prevent the coolant from warming up because the fan only helps cool the coolant in the radiator--not the coolant in the engine. The coolant in the engine doesn't flow out to the radiator until the thermostat opens. Running the fan helps it warm up faster because it puts a load on the engine and t needs to burn more fuel.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
