Originally Posted by 100MPGPLUS
![Cool](/forum/images/smilies/cool.gif) increase mpg
Then I settled on Xylene and Acetone, mixure for my experiment. I went to Ace Hardware, purchased, a Gallon of both. I add 4 oz of each, 8 oz total per full tank, about 20 gallons. I went from 16 mpg to 20 mpg and while the MPG increase, the engine ran with more pick up
I have been using this formula, for three months and I am very happy.
![Turtle](/forum/images/smilies/turtle.gif) Mark G. Cooper ![Turtle](/forum/images/smilies/turtle.gif)
Phoenix, Arizona ![Snail](/forum/images/smilies/snail.gif)
I used various mixes for close to two years and the mix was very good at making the scanguage read much higher than expected MPG numbers which makes for good pretend time but then when I went to fill up my actual MPGs were nearly the same except in the winter where they were consistantly a real 3% (as far as I can tell) above expected. So the cost of the acetone was not recovered by the imagination gain shown on the scangauge.
If all you want to do is make your scangauge read unrealistically high and not check your real fuel economy acetone works wonders.
