Old 10-11-2012, 04:23 AM   #10 (permalink)
renault_megane_dci
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
Originally Posted by gil View Post
Geo Metro XFI cam profile, that is a type of atkinson cycle. It closes early instead of Late. I also like the Idea of adding a turbo to compensate for the power loss.
Atkinson cycle is with an expansion ratio superior to the compression ratio.
It is not do-able with a shorter cam.
FE is doable with a shorter cam : you trade power for efficiency.
Making up a loss of power with a turbo is gonna also "compensate" the FE improvement unless the gearing is altered in such a way that friction improvement (less rpm) makes up for the extra power.
The best way towards FE is less weight / aero penalty hence less power required, power being fuel and air.
The atkinsoning of my engine would be mostly a way to reduce its power while improving its efficiency (I am sure you can imagine ways to reduce power without improving FE ...)
Anyway, I didn't find the Prius cam timing so far ...
