Originally Posted by cRiPpLe_rOoStEr
Actually this is a pretty good idea. Running at a single speed should make scavenging a pretty simple affair (I guess you might have to adjust for air density differences, but I think that's not a big issue if you allow some reasonable amount of trapped exhaust). Have cam actuated valves, fuel injection of course, and a very high static compression ratio. If you really want to chase down the last bit of friction rods can be lightened since they don't have a strong load reversal and thus fatigue resistance requirements.
GM is good friends with Eaton, they can surely strike up a deal for some superchargers with better rotor sealing for scavenging purposes.
