Thread: The Scrapcento
Old 10-11-2012, 08:37 AM   #38 (permalink)
maczo
maczo's Avatar
scrapcento - '99 fiat seicento
90 day: 30.15 mpg (US)
fokus - '08 Ford Focus
90 day: 31.15 mpg (US)
tdm - '95 Yamaha TDM 850
90 day: 27.72 mpg (US)
vespa - '04 Piaggio Vespa ET4
90 day: 57.6 mpg (US)
PCX - '10 Honda PCX
90 day: 78.33 mpg (US)
avensis - '13 Toyota Avensis
90 day: 39.77 mpg (US)
Aaaaand the car is back from the mechanic.
What is not faulty:
- lambda
- brakes (not stuck)
What is not faulty, but causes bad FE. This time not my opinions, but the mechanic's. I didn't give him hints on what to check, apart from the lambda and injectors. Here it goes:
- re-programmed computer with altered ignition timing and fuel dosage. This is a small surprise, because I cannot recall that detail from the swapping process. But the ECU was indeed bought used from someone with a 1.2 'cento, so it kind of fits.
- exhaust too loose (and I don't mean the mounts )
- intake (current is semi-CAI, cone filter)
So now I feel partially excused for getting mediocre FE
The big question is: what now? Kill-switch + aero to coast longer? WAI? (I could probably isolate the filter from sources of fresh air).
Any and all suggestions welcome
The Scrapcento thread
