the 2500 is a 4x4 not an AWD, so the system should be purely mechanical to remove, maybe a couple of sensors.
Its a pretty old school system so it should be as simple as removing the transfer case and front drive shaft and replacing the rear drive shaft with a longer one.
I say simple but its likely a big pain and may or may not be worth it.
It also depends on your driving, if its all highway the weight and drag of 4x4 will be less noticeable than if its all city.
The 6.0L is also a beast so you have to be pretty easy on the throttle to make sure its not just sucking down gas.
Another option for a band which i think would be easier, is a trailer.
You can leave your gear in if you wanted to and you have a ton of options that can tow 2000lbs and get good mileage.
