Old 10-11-2012, 04:35 PM   #26 (permalink)
christofoo
christofoo's Avatar
00C - '00 Toyota Corolla
90 day: 43.54 mpg (US)
Originally Posted by Sven7 View Post
Would half tubing even be worth the effort? Even if you could maintain attached flow (with no belly pan) would a radius make a difference? The front of the car is a very high pressure zone and you shouldn't have even a hint of trouble there.
I'm afraid I don't see your point. I think the goal for an air dam lip radius is to prevent (or reduce) vortex generation at that location. I thought flow attachment is an issue for sloping surfaces in the wake.
For sure duct the cooling. If you can patch that hole, it'll probably be better for aero to make it a "bottom breather" and move the cooling intake underneath the nose. This maintains clean airflow over the nose instead of breaking it up when it passes the vent.
The reason I didn't move the intake down further is because the nose doesn't seem long enough; the intake duct would have to be at a steep angle if I put it all the way at the bottom. I could see why it still might be an advantage but I felt uncertain.
Another todo I forgot: intake block, esp. for commuting.
