Old 10-11-2012, 11:34 PM   #8 (permalink)
Formula413
Renaissance Man
Formula413's Avatar
Aegean C - '17 Honda Civic LX
90 day: 38.06 mpg (US)
Another update: I'm at the halfway point, and I think I may have found a big part of my pack's problem. Subpack J (I used letters instead of numbers) returned only about 800 mah on its initial discharge, while most subpacks were around 3,000 mah, and one as high as 4,000 mah. Obviously with over 3,000 mah of capacity separating the strongest and weakest subpacks there was very little useful capacity. That weak one showed a capacity of only 4,349 mah on it's first charge, but subsequent cyclings brought that to 5,955 mah, 6,001 mah, and 6,069 mah. It's still the weakest subpack so far but well within established tolerances for a useable subpack. I'm giving it one more cycle to see if I can pull some more out of it. So far the results I've seen make me very optimistic about how the pack will perform once I'm finished.
