Old 10-12-2012, 02:10 AM   #5 (permalink)
redpoint5
90 day: 38.47 mpg (US)
I had no idea Li-Ion cells came in anything other than small cylinders. I've seen Li-Po batteries in various sizes in rectangular shapes, but I'm not sure how the chemistry differs from Li-Ion.
I use 48 A123, they are roughly C-cell sized.
Next time around I plan on using paper backed book sized rectangular cells.
Buying the raw cells is a lot cheaper then getting a premade battery.
Why would you go with with rectangular cells if the A123 are cheaper?
I would think making larger cells would be more cost effective for companies like Tesla. Much less complexity for a BMS, less cost in packaging, and most importantly, higher energy density since less packaging material is required, and less space is wasted due to fitting cylindrical objects into a rectangular area.
