This is the one that has +/- supplies for the gate driver split with resistor/zener from one voltage ?
Do you have enough low-ESR capacitance for both sides directly in the supply pins of the driver ic ?
I couldn't find the schematics and BOM for this.
Edit: Other proposal: Measure the capacitance across gate power isolation.
Reason: addition
