Old 10-12-2012, 01:22 PM   #12 (permalink)
beatr911
B2300 - '96 Mazda B2300 SE
Focus - '05 Ford Focus ST
The red car - '00 Honda Insight
A little searching found some info on the Mazda Millenia with a 2.3L V6 with actual Miller cycle engine.
Link:
Why hasn't the Miller cycle been more widely utilized? - Motor Trend The General Forum Forum
"Miller Cycle is an interesting concept. Invented by American Ralph Miller rather than Mazda in 1940s, it changed the long-standing basic principle, Otto cycle. Conventional Otto cycle engines have 4 stages in each cycle - intake, compression, explosion (expansion) and exhaust. Each of them takes roughly equal time. Miller Cycle engine differs from it by delaying the inlet valves closing well into the compression stroke. What is the result of this ?
In Mazda's Miller Cycle V6 engine, inlet valves close at 47 degrees after BDC (bottom dead center, ie, the lowest position of piston during a cycle). This equals to 20% of the height of stroke. In other words, during the first 20% of the compression stroke, the intake valves remain opening, thus air flows out without compression. Real compression activated during the remaining 80% stroke. Therefore, the real effective capacity of the engine is only 80% of the volume of combustion chamber. Compression ratio is decreased from 10 : 1 to slightly under 8 : 1.
Valve timing of the Miller Cycle V6
Until now, you probably still don't understand its objective. Be patient, I am going to explain now.
Lower compression ratio means less energy loss in compressing air, i.e., the so-called "pumping loss". Moreover, lighter compression leads to lower temperature, thus reduces heat loss in cylinder wall and pistons. To compensate the reduction in real capacity, a supercharger is employed to increase the air density such that the engine actually resume 100% capacity. Of course, the supercharger must generates less pumping loss than those gain by reducing compression ratio. Otherwise Miller Cycle engine will be no more efficient than ordinary engines.
Note that the expansion stroke is the same as ordinary engines, it is not reduced like the compression stroke. As a result, power delivery and is as smooth as normally aspirated engines.
Disadvantage
Mazda's Miller Cycle engine burns 13% less fuel than its 3 litres conventional sister engine. It also generates more power and better torque curve. However, since its introduction in 1994 until now, no other car makers follow its trend. Even Mazda itself did not produce another Miller Cycle engine. Why ?
Think about it: although it is claimed to be a 2.3-litre engine, it is actually constructed as a 3-litre engine, no matter in dimensions and in material. Then, the supercharger and twin intercoolers (one per cylinder bank) will be extra cost compare with conventional 3-litre engine.
For a V6, this might be forgiveable, but those additional cost will be relatively expensive for a low cost four-cylinder engine. As a result, Miller Cycle concept can hardly be popular in the market.
My comments:
If I understand the article correctly, utilizing only 80% of the stroke of a 3.0 liter engine makes it a (3.0)(.80) = 2.4 liter engine. Manufacturing a dimensionally large engine to have a small displacement in combination with a supercharger does not appear to be advantageous from a cost benefit standpoint.
Read more: http://forums.motortrend.com/70/7352643/the-general-forum/why-hasnt-the-miller-cycle-been-more-widely-utiliz/index.html#ixzz296cYYy6x"
So the only cam timing information is the intake closes 47* after BDC. Hmm. A cam event diagram (see attachment) from a Suzuki GS500 shows the intake closes 62* after BDC theoretically making it even more of a Miller cycle than an actual one. Need more data on the rest of the cam events on the Mazda.
Good design is simple. Getting there isn't.
