Originally Posted by MetroMPG
You know you're an ecomodder when...
you have exploded the air hose on your bicycle pump... while pumping up your car's tires. (Man, that was loud! Went off like a firecracker.)
Fixed it: there's now a slightly shorter air hose on the pump.
Or when you find that the "lighter socket powered air compressor" you got cheap with your fuel doesn't really support the pressures you are after, even if the gauge goes to 2x your target.
But you sit for 30 mins on each front wheel waiting for it to work.
In -1 Deg C.
Winter has arrived in Caledonia.
