Thread: The Scrapcento
Old 10-12-2012, 05:05 PM   #41 (permalink)
AndrzejM
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Originally Posted by maczo View Post
OK, my bad. Not all mods welcome, I will restate that I don't want to compromise performance.
So go for weight reduction, it will increase your performance, and FE
WAI could be de-installed quickly for events.
That can be done easily
How much of a gain would DRLs give me?
55W per each headlight, 5W per each front position light and 10W per each rear position light so it will be 140W depending on alternator efficiency the gain will be between 0,2 to 0,3 HP
I'm thinking more and more about the vacuum gauge. Am I right that the rule to follow is:
a) when accelerating, aim for the least possible vacuum (small negative numbers)
b) when maintaining speed (i.e. on highway), aim for most vacuum (large negative numbers) in top gear
Right?
For FE it's good to maintain high vacuum for all the time
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
