Thread: The Scrapcento
Old 10-12-2012, 08:29 PM   #43 (permalink)
maczo
maczo's Avatar
scrapcento - '99 fiat seicento
90 day: 30.15 mpg (US)
fokus - '08 Ford Focus
90 day: 31.15 mpg (US)
tdm - '95 Yamaha TDM 850
90 day: 27.72 mpg (US)
vespa - '04 Piaggio Vespa ET4
90 day: 57.6 mpg (US)
PCX - '10 Honda PCX
90 day: 78.33 mpg (US)
avensis - '13 Toyota Avensis
90 day: 39.77 mpg (US)
Originally Posted by AndrzejM View Post
So go for weight reduction, it will increase your performance, and FE
The no. 1 weight-saver would probably be removing the spare tire, but then I wouldn't feel to confident in case of a flat tire in the middle of nowhere. I do have a spray-can ad-hoc sealant but I'm not sure this would suffice. Any thoughts/experience on that?
[with DRL] the gain will be between 0,2 to 0,3 HP
Will that have a measurable influence on FE? I think most notably it will decrease the idle consumption, so with P&G maybe also a bit improve real-driving FE just that tiny bit. But is that on the order of 1% even?
For FE it's good to maintain high vacuum for all the time
I was thinking high vacuum reading would mean high engine load and (assuming low RPMs) optimum BSFC. Is this true?
Originally Posted by Piwoslaw View Post
DRLs would work nice with an alternator delete, or at least alt on/off switch. During races you could take the alternator belt off, which would free up not only the electrical load, but also mechanical belt losses, probably ~1-2hp total. Just make sure you have a healthy battery!
Soooo... P&G = alt off, DFCO = alt on? Rinse and repeat?
As for belt off, I think it will be risky for Saturdays. Usually there is quite a lot of driving and the schedule is tight. This means no room for battery going dead. But fur Sundays' super-stages that might be a viable option (if it's not violating the rules, which I think it should not). I just need to see how much work it takes to remove and re-mount the belt.
The Scrapcento thread
