Old 10-14-2012, 07:44 AM   #1 (permalink)
Toybox
Toyota magnetic vss sensor help
Hello all,
I'm trying to fit my MPGuino and I've run into a snag.
The injector connection was a piece of cake but the VSS is proving tricky.
The automatic gearbox uses a 2 wire magnetic sensor and the 4 bolts on the propshaft as the trigger. From what I read the sensor produces 5V as the bolts pass across the magnet.
The MPGuino does not seem to like this signal. It works at higher speeds (over 20 - 30 km/h) although it seems a bit erratic.
Any assistance would be much appreciated.
