The problem with weight reduction on a suburban is you can spend a lot of money to get nearly no return, if you drive a lot of highway miles a 100lb reduction is only going to get you a 0.1mpg improvement.
In stop and go it might help a little more.
Are you sure a 100lbs reduction in vehicle weight saves 0.1 mpg ? I have always heard a 100 lbs reduction in weight saves 1 mpg. With 0.1 % of gain a 1000 lbs reduction in vehicle weight would save 1 mpg, not !
![Thumbs up](/forum/images/smilies/grinning-smiley-003.gif)
