Old 10-15-2012, 09:40 AM   #121 (permalink)
ThomCat316
Originally Posted by JRP3 View Post
I've never used peel ply, does it completely take care of the amine blush issue, or just reduce it?
If you let the layup cure fully (or better yet, post-cure it) the free amine will be on the surface. When you peel the surface off the blush goes with it, and the remaining surface is ready for application of additional resin, filler, or primer without sanding.
I like the stuff. :-)
As always, experiment with a small sample first to make sure you like it too....
