Chances are those civics are either taking advantage of the lean burn function or they are engine off coasting. Shifting sooner if your shifting under 3000 try lower if you can shift up and not lug the engine its a plus.
Civics are probably using a device of some kind thats aftermarket whether its a scangauge or mpguino. Mpguinos are popular on civics because they give the fuel readouts during leanburn
"The only real mistake is the one from which we learn nothing."
- Henry Ford
