Old 10-15-2012, 05:46 PM   #21 (permalink)
Gealii
The Dirty330 Modder
Gealii's Avatar
CruzeRS - '15 Chevy Cruze LT RS
90 day: 41.29 mpg (US)
I would go with the Ultragauge at least at first. The only reason i see getting a scangauge is if you have a hybrid. The Ultragauge has all the same functions as a scangauge minus the hybrid help. It can be used as a code reader, is more accurate the factory needle gauges, and can be calibrated to closer to your mpg readouts. The ultragauge is also much cheaper than a scangauge. And plugging into the obd2 port makes it easily exchangeable to another vehicle
"The only real mistake is the one from which we learn nothing."
- Henry Ford
