Originally Posted by ron
so what was the cost of the used engine verses the head gasket replacement cost. dont count the hastle factor
A head gasket job would have cost me less than $100. But I will have to change out a lot of gaskets and fix a few other leaks, properly about $300 in parts total.
With what I did
The used D16Y5 with TRANNY, ECU, LINKAGE, DRIVESHAFTS $400.
Machine shop for cleaning, decked, and a valve job $300 (local)
A rebuild kit with new water pump and oil pump $280 (eBay)
A wiring harness because I wanted a factory complete look $130 used (eBay)
I sold the D16Y7 as is for $200 on CL. So a total cost of $900 was the cost to have this swap done plus about 40-50 hours of work! (mostly cleaning and monkeying rusted parts)
