Old 10-16-2012, 01:02 AM   #38 (permalink)
serialk11r
Originally Posted by Firestarter View Post
Turbos raise engine efficiency. The manufacturer needs to do gearing and other changes to take advantage of this. This is why all BMW's are turbo'd now.
This is pretty iffy. The 335 and the 328 are the same engine pretty much but the 335 has lower compression and twin turbo. The 335 has poorer fuel economy. Fuel economy goes up if you decrease the engine size and then turbo to make up for the power loss, because it decreases the friction you have to deal with.
BMW engines are all Valvetronic equipped except the high performance Sxx variants. This means off load boost actually can help thermodynamic efficiency.
As people have already figured out with the best BSFC at 80% load rule, increasing power production stops increasing efficiency before the engine hits full load. A usual throttle plate controlled engine might see a slight improvement in thermodynamic efficiency from a turbo at an operating point where the throttle is nearly fully open, but the valve timing is set up so that the engine is not at maximum torque output.
