I've been doing this for a few years now and I've tried all the combinations of load and rpm. 1500-2000 (sometimes 2200) and 80-90% load (13 psi MAP) is the best for mileage in these Hondas. On flat ground I can gain speed from as low as 1000 rpm, so 1500 is a conservative limit you can stretch and go lower if you like.
![](http://ecomodder.com/forum/fe-graphs/sig268a.png)
