Old 10-16-2012, 07:25 PM   #37 (permalink)
ecomodded
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
[B]Refidgerator is insulated[B]
I have finished insulating my fridge, it was a success giving a 38% improvement in efficiency/energy consumption.
I also added a rear exhaust vent for the insulated compressor / condenser area to exhaust into a hall closet, instead of the kick panel.
I used 4 layers of 'SolidBlack' wood flooring insulation and one layer of blue vapor barrier over top along with 2 cans of 3M spray adhesive .
The under fridge is completely covered from kick panel and lower sides to the back of the fridge with a 4 layer sheet of SolidBlack. You can see it sticking out at the bottom of the fridge, that will be bent upwards and put in the top of the vent.
I am currently testing 10 gallons of water in 2 liter jugs in the bottom of the fridge.
I'll post back with the gains or losses from the PCM's (water jugs) when i collect more data.
ID:	11665   Click image for larger version
ID:	11666   Click image for larger version
Name:	Fridge vent 001.jpg
ID:	11667   Click image for larger version
Name:	Fridge vent 004.jpg
ID:	11668   Click image for larger version
Name:	Fridge vent 006.jpg
Name:	Fridge vent 007.jpg
ID:	11670   Click image for larger version
Save gas
