Originally Posted by ron
"brown oil" when left alone will separate or the water will evaporate. perhaps you should have said water injection .Ive used that and agree it keeps the combustion chamber clean.to say water burns you must be referring to splitting hydrogen off or HHO
Hence the "small quantities" of emulsion. I burn it faster than it can separate. I don't have a mix tank installed on the vehicle so I have to mix only what I can use for the tests.
I don't use water injection on my diesels, though I'm considering it, since it's so easy to mount a carb and feed it water and meter it properly.
I said water burns because it's true. I didn't say I'm burning water.
