Originally Posted by PaleMelanesian
I've been doing this for a few years now and I've tried all the combinations of load and rpm. 1500-2000 (sometimes 2200) and 80-90% load (13 psi MAP) is the best for mileage in these Hondas. On flat ground I can gain speed from as low as 1000 rpm, so 1500 is a conservative limit you can stretch and go lower if you like.
Hey PaleMel there is no messing with success and i have seen some of your impressive data and results in other posts, so you definitely know how to drive those hondas.
Let me ask you what is your typical acceleration times to get up to 40 mph and up to 60 mph from rest--in units of time in seconds or minutes
such as the case may be...?
