Old 10-17-2012, 02:56 PM   #3 (permalink)
SpeedyCorky
also races Sportbikes!!!
SpeedyCorky's Avatar
Mo' Mon-nay! - '00 Honda Civic HX
90 day: 52.26 mpg (US)
Carbon Silver - '06 Honda Insight
90 day: 82.2 mpg (US)
i've cleaned out the EGR, it was pretty clean when i was in there. I did not remove the whole fuel rail tho - however I doubt that is the problem, considering how clean it was around the EGR itself
UPDATE: on my way to work today I was *somehow* able to keep it in lean burn for a good couple minutes. the motor was semi-cold (not fully warm, about 4 minutes from startup time) when i was able to achieve this. However, as the motor warmed up more (about 20 minutes from start up), i was unable to get it into lean burn for more than a few seconds..... WTF is going on!? is the CA ECU screwing me?
granted, for the couple minutes that I was able to keep it in lean burn - i got VERY good *instantious* mileage, like a good 8mpg more than i would normally get during that section of my commute.
2000 Honda Civic HX with mild aero mods
2006 Honda Insight
MIMA, FAS, no passenger sideview mirror, race style drivers mirror, front and rear underbody aero, temporary front air dam
