Hey palemelanesian
So lets see here a couple things if I'm learning correctly
80-90% load as long as I am in closed loop
Short shifts (try to be under 2000 rpm)
Stay in closed loop
What about TPS % I hear a lot of different things?
What is a good WAI Temp or do you look at this?
Also I know people say coast in neautral to a light but what if I'm coming to a stop should I downshift and use my gears to slow down? Doesn't it go into lean mode if I do this?
Coasting in neutral just goes into reguluar idle fuel mixture reading doesn't it?
1998 Honda civic Lx sedan 5sp completely stock with lowering kit 2in drop full fresh factory tune up and ngk plugs ngk blue wires. Just added vacuum gauge
